I was doing a little reading up on biodiesel and I am convinced that this sounds like a really good way to go. From what I can tell, here are the pros and cons:
CONS:
1) Contains methanol, so it will dissolve natural rubber (o-rings, seals, hoses, etc). Most newer diesels use synthetic rubber for all this stuff anyway.
2) Will dissolve concrete.
3) Can't "soot" someone-- you will have to settle for coating them with veggie oil
4) Might not smoke as nicely
5) Truck smells like french fry cooker
PROS:
1) Cheaper to run. Biodiesel is easy to make from soybeans, corn, you name it. Almost anything that can be made into veggie oil can be made into biodiesel.
2) Lower emissions
3) MUCH better lubricity than regular #2
4) Burns CLEANER, and tends to dissolve deposits, not leave them
5) Similar gelling/clouding qualities as regular #2
6) Similar BTU content-- about halfway between #1 and #2
7) COMPLETELY RENEWABLE-- we can make it start to finish here in the good old USA. no waiting a million years for crude to form. No paying a raghead money he will use to kills us for Allah.
That last one should actually be about 4 or 5 pros in one...
HOHN
CONS:
PROS:
2) Lower emissions
HOHN
