Expensive lesson learned - for about the last month, I've noticed that the right front brake wants to lock up first in the rain. Other than that, no pull to the right or anything.
On Wednesday we had to tow our 13,500# 5th wheel through AM rush hour traffic in Houston to get the refrigerator replaced - the trailer brakes are controlled by a Tekonsha Sentinel inertial brake controller. We had been stuck in stop-and-go traffic for miles, and I had just stopped for a red light when my wife said, "That truck in front of us certainly is smoking!" Sure enough, white smoke was rolling up over the right front of the 3500. Well, the truck took off when the light changed - you guessed it - no smoke. I start thinking, "Uh-oh!" The next stop, here comes the white smoke again. I'm watching the gauges and listening for transmission slippage just knowing that I've blown a water hose or a transmission cooler line! Naturally, there was nowhere to pull off until we reached the trailer repair shop about 2 miles later. By this time, I'm reaching for the fire extinguisher as I get out and find the right front brake literally smoking!!
The problem - right front caliper was frozen on the pins (i. e. , wouldn't slide). The result - 2 new calipers, pads and associated hardware. New wheel bearings and grease seals on the right front. Brake system flush to get rid of the "burned" brake fluid. Fortunately, the rotors weren't warped.
An expensive lesson - keep an eye on those blasted front brakes!!
I'm sure I won't have this caliper sticking problem on the 2002 since Dodge has certainly fixed it by now, right??
Rusty
Rusty
