My 2012 (they should have the same emission system) is the same and I suspect, like you, that the core of the DPF is fractured and is letting soot through.
From my research, it shouldn't be a problem as long as the leak remains within certain value. The reason is that PCM does not monitor the DPF directly (i.e. by measuring soot post DPF), but by interpreting the readings it gets from the pressure sensor.
Generally speaking, if the leak is too big, the differential pressure will fall below a certain threshold and trigger a code, specifically code P2002.
"The aftertreatment diesel particulate filter is designed to physically filter soot and to eliminate hydrocarbons from the engine exhaust gases through catalyst reactions in the exhaust stream. Federal law requires that the filter's efficiency be monitored for signs of degradation that would compromise the efficiency of the filter. The ECM monitors the efficiency of the aftertreatment diesel particulate filter via interpretation of data received from the Diesel Particulate Filter Pressure Sensor, which monitors the restriction across the aftertreatment diesel particulate filter. The ECM monitors the restriction in the aftertreatment diesel particulate filter at various engine speeds/loads and will set the fault if the restriction is below a calibrated threshold minimum value. The ECM will illuminate the MIL light Immediately when the diagnostic runs and fails in two consecutive drive cycles. Active regeneration of the aftertreatment Diesel particulate filter will also be disabled for the remainder of the drive cycle. The ECM will try to regenerate the aftertreatment diesel particulate filter on the next subsequent drive cycle. The ECM win turn off the MIL light immediately after the diagnostic runs and passes in four consecutive drive cycles."
I wouldn't worry too much about it, but since you are still within the emission warranty period (8 years / 80,0000), I would pay a trip to a few dealers and express your concerns to see if you get it replaced.
Alternatively you can keep an eye on eBay or your local CL: these trucks get deleted all the time and I see DPFs going for $300-$400. If you buy a used one, inspect it and make sure that is sooted on the inlet side (the side with the colt on flange) and not the other side. That should be a good unit. With your old one, check you local recycling center see what they pay you for it. It contains certain precious metal so you may be able to get a few bucks. There's also specialty recyclers.
