Blackstone Oil Analysis Question
details on the 24v head on 12v motor
Auto transmission upgrades for our trucks
I just got a faxed copy of my blackstone lab oil analysis back. Does anyone know what the Universal Averages are for the different elements in the 6BT 5. 9 (Our beloved 12V) engines? That's the column all the way to the right and it didn't come out at all in the fax. Just a black column. Thanks for info in advance.
Steve
1998 2500 Quad Cab, 12V, 5spd, 4x4, HD Transfer Case, 370HP Diamond B Injectors, #4 TST, 16cm2 Housing, AFC Spring Kit, BD Governor Spring Kit and other modifications, Walker Muffler, 285/75-16 BFG AT's, Stainless Steel Tube Steps, Reese Fifth Wheel Hitch, Leather, CD, LSD Dana 80 Rear, 60 Front, Centerforce Dual Friction Clutch, Rancho RS9000 Shocks, Rancho Steering Stabilizer, ATS Exhaust Manifold, Psychotty Air Induction
Steve,
Here you go:
Aluminum 4
Chromium 2
Iron 24
Copper 7
Lead 6
Tin 0
Molybdenum 8
Nickel 0
Manganese 1
Silver 0
Titanium 0
Vanadium 0
Boron 163
Silicon 9
Sodium 11
Calcium 2252
Magnesium 465
Phosphorus 1063
Zinc 1214
Barium 1
I think the last five #'s are dependent of the brand of oil you use (they are additives). Hope this helps.
1996 Dodge 2500 4X4 SC, SLT, Cummins 12V, 5-spd. , JRE 4" exhaust (my kitty ran away into the woods and the muffler fell off!), TST 280 HP/685 Ft-Lb Uprate Kit, AFC Spring Kit, Horton Fan Clutch, Jacobs/Ram Exhaust Brake, MagHytec Differential Cover, Prime-Loc, Rancho RS9000 Shocks, Combo Gauge, K&N Air Filter, Brite-Box, Geno's finger-touch oil pan drain plug, Optima Yellow Tops, no turbo silencer ring, full-time fog lights.
