Archived BLeeding Clutch Slave Cylinder
Archived Brakes in Rapid City SD
Archived Fellow Member Down In Nashville
I have a 2001 with a 5 speed, I had the clutch replaced and there is not a bleeder connection to bleed the system. The system has air iin it, what is the magic on how to bleed the system ?
There isn't a bleed valve on this system. It comes as a closed sealed system - master/slave and lines.
Changing the clutch should not require a bleed (unless someone opened the line by mistake).
Some members claim success in removing air. Search the 2nd gen forums for clutch bleed.
