I just replaced the intake manifold gasket to try to find the 5-6 pounds of boost I have lost. I loosened the high pressure lines and now it won't start. Before it would start almost instantly.
I bled the low pressure side, the pump, and tried to bleed the high pressure lines. When I use the lift pump, I can't see any effect at each injector like I can when I bleed the low pressure side and the pump. I have a 1991 motorhome with the rotary pump. I energize the fuel solenoid with the key and pump over 200 strokes with the lift pump. With just #1 cracked, no fuel or air comes out. I also get the same result at the other injectors.
When I crank it with the starter, and one injector line loose, it leaks all over the place. I do each injector the same way and get fuel every time. But, it still won't start.
Two questions:
1. How do I check whether it is sucking air?
2. Is it possible to hook in an electric fuel pump between the lift pump and injection pump, and bleed the entire system that way? What is the thread size for the connections of the lift pump?
Any thoughts on the subject would be appreciated.
Tom
Two questions:
Tom
