Jgann,
I have the DSE kit and tomorrow I hope to get a barrel of WVO (50 gal)... You might have seen my station on the other thread...
In the DSE Blend of 20 gal. wvo and 2 gal kerosene (10%), (can optionally do 20% diesel) , and 1 gal. RUG (5%) and 15 OZ PS cetane boost and 3. 5 oz DSE additive..... Says is supposed to be good down to 30 deg... .
Now, If I take that mixture, and mix THAT, with #2 diesel so it would make 46 gallons total, (50-50 mix), they say it should be good enough for almost any winter temp...
I assume the RUG and the DSE additive is to make the Glycerin stable for burning and to prevent gelling as well as the Kerosene... ... So, add that to 50% #2 diesel, it should be good down to 0 deg. or so right?
For lower temps, They suggested add 5% kerosene for every 10 degree below 30 deg. ... so that is 3 gallons of kerosene... or 6 gallons of Diesel (for the optional way)... makes to 0 deg..... So if you have like 20 gallons added to that origional mix, Seems like it is very much lower than 0 deg. rating... Like -10 or so... .
When I do my mix, I have several glass jars I am going to put in the freezer and in a chest fridge to test at 0 deg. , and 30 deg...
also the test at those temps will be the DSE mix... . full strength DSE,... . 50/50 mix... . and 75% diesel / 25% WVO-DSE ... . and see what the mixtures do in the different temps.
Will post my results when I do it... .
What do you think?
