Yeah get used to walking if you take the truck tot he dealer to repalce the freeze plug. they work in a shop all day long or at least They are supposed to work But do you seriously know how often they replace freeze plug? do you know how often they replace them properly? I would seriously consider towing the truck to a reputable gasoline engine builder (more of them than race diesel builders) and never have a problem ever again unless you mix coolant wrong again. Also somebody is responsible for the freeze plug coming out. Whether it was you, jiffy lube, or the dealer I cannot say but your records can. get a hydrometer and test the remaining fluid in the system. make sure that too much water is not the cause of failure if it is last personal who serviced coolant needs to pay the repair and tow bills, not to mention the hazardous waste clean up where it finally dumped. Also I would consider cleaning it up quick cuz if the mice drink it and go in your house and die under the bathtub or behind the walls for instance its a few thousand dollars and very stressful and hard to live in a house with a rotting animal. I speak from experience of trying to use antifreeze to poison the fsuckers.
But get a hyrdometer and check that coolant if it is not of correct mixture than goes after who ever mixed it. if the mixture is correct good luck with dalmer chrysler cuz they will swear up and down incorrect mixture even though the mixture sample is sitting there in the bottom of the radiator. But a freeze plug is a major thing in my book I sure as heel wouldn't want failure when i am 500 miles from home or on my way to work ( cant lose job) if its a the DC dealer if it were mine I would load it up and take it else where cuz you are looking at too much of a liability issue with DC techs repairing you problem.
The guy who posted about enterprise engine has the solution that sounds best to me since you are going to a reputable shop.
Yes, call this dealer and ask for the cooling adapter that replaces that freeze plug with a adapter to bring water from the rear of your head up to the front. It cools #5 & #6 much better and reduces the pressure on that dead end cooling passage. Also, you'll never blow that freeze plug again. Win-win all around. Check it out.![]()
http://www.enterpriseengine.com/
Derek,
Why dont you do some reading on why these plugs fall out before writing a book of non-sense.
On second thought, keep writing its very entertaining. I love how it goes from antifreeze to a mouse dying inside the wall of someones house! The masked f bombs will also get you far on this website.
I like hte idea of the coolant plug to move the water out from the back to the front. that's a cool idea.
I'm too lazy to call Enterprise - anyone know the price?
what dealer?dodge or enterprise?Yes, call this dealer and ask for the cooling adapter that replaces that freeze plug with a adapter to bring water from the rear of your head up to the front. It cools #5 & #6 much better and reduces the pressure on that dead end cooling passage. Also, you'll never blow that freeze plug again. Win-win all around. Check it out.![]()
