Blinker issue
53 block
Nv4500 5th gear hanging issues
2001 24v H.O, so on the dash the left turn signal stays lit until you turn the turn signal on flashes really quick on the dash and the light itself is also really dim Already replaced the bulb, any ideas of what to do next? Fuse is also good
Update replaced theflasher really it slowed it down to blink normal, but left front is still dim and when lights are on the left indicator is still let up until you turn it on
You have a bad ground to that light/side. Check front and rear and see which one is dim, tha0.t will be your bad ground. Might have to replace the socket assy. or just solder a wire to the socket and tie it to a good ground. bg
