Guys, while knocking the front end of this truck apart for the BIG overhaul, I remembered the turn signal and hazzard flashers werent blinking. I read the thread posted earlier about the flasher, they mentioned it being in the fuse panel. Ok, I looked - didnt see anything that looked like a flasher, checked the fuse/relay box under the hood, nothing, took the cover off from under the column, pulled the glove box - nothing. Where'd they HIDE that flasher on this thing???
It is a 2000 model. Since neither flashes, I cant use my ears to trace the sound. Aso,is it normal for the turn signals to be able to turn on when the truck ignition is turned off? Oh, I checked the bulbs - all good.
