I had a problem with my block heater cord getting all iced up and wet, then it would occasionally trip the GFI circuit in my garage and leaving me with a rough start in the morning. My brother had a GMC Topkick and I noticed that it had a male plug with a spring loaded cover mounted to the bumper. so any way I called my local GM dealer:--) they wanted 60 bucks! for the plug!
The alternative: I took a Polock 7-pin female socket and removed the guts, then I cut the back side off about 1. 75" from the mounting surface. Then I found a Hubbel brand 110 ACV male replacement end (I will find the part # if any one is interested)
It was so close the plug almost slipped right in, but I had to use a drum sanding attatchment on a Dremel tool to open it up a bit.
Once it fit together I positioned the prongs about 1/8" from the inside of the cover, then carefully drilled 2 small holes into either side of the plug through the original screw holes in the socket and used the original screws that came with the 7-pin to hold the guts in the socket. I then cut a hole in my front bumper, cut the heater cord and connected it to the new plug applying silicone generously to the back, and mounted the whole shotin' match in the bumper
Haven't had a cold start in the mornin' since!
any one want more info or pics let me know.
Proto
http://www.msnusers.com/CTDfans
Proto
