Double check the connection at the block heater itself.Any suggestions?
Prep Work at {most} dealers = remove plastic from seats / wash vehicle. :-lafI still have not figured out why it was missed during prep of the truck at the dealers.
That's just the 6.7L Cummins way. :-lafIt works, just doesn't make any noise.
I didn't think mine was working. No noise on plug in. Check your EVIC for the coolant temperature. I believe mine was 80* the other morning when the outside temp was 14 and wind chill was 0. The EVIC temp should give you a clear indication as to whether or not it is working.
I smell dumplings with a little bacon when my seat heaters are on high![]()
