Blocking Off Wastegate!
The below was recently posted in thread 'torque plates'. Hope it helps. See no reason for concern as long as your EGT's remain below 1300 pre-turbo.
Just another data point. Prior to installing a TST #6 plate, last weekend, I took my stock plate and slid it "all" the way forward (did not increase slot lgt. ) as well as the AFC forward, 20 clicks in on the AFC starwheel. Checked adjustment on cam contour follower so it did not ride under plate. Also blocked off the turbo wastegate. I will use this as a baseline to the #6 plate performance.
Seat of the pants indicates off line response is much better, turbo spoolup comes on almost immediately, very little smoke, max. boost now hits 28 -30psig (vs 18 stock psig max) and EGT now max's @ 1250 (vs 950 stock). Govenor still stock, so defuel takes place at ~2700RPM. Mid range torque is greatly increased. Bottom line - vast improvement stock!!
1995 2500, std. cab, auto, bone stock, correct gages. 110K miles
