Engine/Transmission (1994 - 1998) blow down tube
Engine/Transmission (1998.5 - 2002) Dyno Testing
2nd Gen Non-Engine/Transmission Changing headlight switches
just got my georend trans/converter in,while under looking for leaks or such, i noticed that a steady stream is pouring from my vent tube. i know this is somewhat normal. i was wondering what to look for if anything ?
thanks, scot
I'm asuming you are talking about the crank case vent? If so see below.
That's pretty normal. I can't tell you if it's excessive or not without seeing it. Vacuum leaks can cause extra vapor to come out. Also a bad turbo seal can do this but that would only be happening while you had boost and not at idle like you are seeing. I would guess that it's all fine and good.
