A BOV won't help with turbo chirp, or barking the turbo, that is a different valve. A BOV is used to release excess boost, In my case my BOV's there are 2 are set at 70# as I don't want to go over 75#. With a set-up capable of well over 70# mine release the excess well before I up-shift in second and third. If you want help with barking the turbo you will need a unit such as the BD Turbo Guard. Barking the turbo is caused when the throttle is closed quickly at high boost. When the throttle closes there is high pressure after the turbo and now no drive for the turbo, so the high pressure in the intercooler etc. forces the turbo to stop almost instantly and then makes the turbo reverse direction. This condition is well known for broken shafts on the HX35 & 40 turbo's they use the same shaft.
Bruce
