sure, but why?
if you plan to use it to get rig of "turbo bark" keep in mind:
with a wastegated single you will have to set it a little higher than wastegate actuation pressure. there are no throttle plates for the air to slam against so when you let you foot off the pedal fast you'll notice that your boost pressure wont go high enough to set it off anyway.....
other than that, some people use it to control max boost on twins or unwastegated singles.
