Blower control problem?
Anyone order a dashtop directly from PALCO Industries
Build sheet
Just noticed that the driver side vents are blowing cold air when AC is on and passenger side is blowing warm air and it doesn't have dual cliamate control. Can change it from recirculation to fresh air intake and it is the same. Anything in the dash doesn't seem like and easy fix. The DW would like it fixed. :-{} Any ideas
^ x2 I've heard low on refrigerant can be the cause, with reasoning something about the specific way the evaporator coil is mounted, a temperature gradient across it (due to low refrig) ends up with passenger side warm, and other vehicles evap is mounted differently so that doesn't happen. I've also heard explanation it could be one of the inside air doors broken. Mine does same thing but seems intermittent, seems to change (pass. gets colder) sometimes when I go over a bump. My truck isn't driven in winter; plan this winter is to tear the dash apart and do the door upgrades. Not looking forward to that. The Cummins is great, but comes with a Dodge wrapped around it... .
Thanks for the advice! I new it wasn't cooling as good as it use to but thought it knda wierd that one side was cool and the other was warm. :)
