Unplug the wire from the switch, low pressure is on the accumulator. Use a multimeter set on resistance and probe the two terminals of the switch, low switch will show no reading below about 25 pounds and should show continuity above 43 pounds. The high pressure switch should show continuity up to over 400 pounds and resets at 3590 pounds. I'm not sure where the high switch is located but it will be at or on the discharge line from the compressor to the condenser which is mounted in front of the radiator. bg(
