After searching the threads I think I already know the answer to this question but I want to be sure before embarking on a project of this magnitude. When the fan is blowing on high (AC or Heat) it sounds like I am flying in a Cessna and the air movement feels weak. It will switch from defrost to main to floor but the noise remains and the air flow seems about half what it used to be. I am assuming it is the blend door issue and with summer right around the corner I need the AC to work at its best. It would be a bad summer at 105 degrees and 60% humidity with a weak AC.
I have read the thread about replacing the blend door housing, but I was curious as to when they started to put the upgraded unit into new trucks. I didnt think it was an issue with the '06 and later. I certainly dont want to spend the $800 for the dealer to do it but I am not looking forward to tearing my dash out. :{
If there are any other things I can check first I will investigate those first.
Thanks!
Thanks!
