well I got it replaced last night and now the truck doesn't take as long to cool down, so if your truck is taking abnormally long to cool down start looking for loose hose connections and blown gaskets-I didn't remove any fuel lines but did remove some of the keepers and loosend the others, it's a tight squeeze against the radiator but it can be done without damage-chris
chris sutton
1999 2500 24v qcab longbed 4x4 red sport w/ all the options 'cept plow pkg, 4:10 detroit locker in rear & front ARB,
5" skyjacker lift w/ 35" BFG MT's on 16. 5x9. 75 Weld rims, black smittybilt step bars, black 3 pc. bug persuader,
black lumber rack, camel leather int. w/ mb quartz spkrs and JL Audio twin 10"sub stealth box under rear seat , PE EZ, DTT vb & tc, mag hy-tec transmission pan,
red magview diff covers front & back, SPA pyro/boost&fuel pres/oil temp on "A" pillar,K&N/scotty,BG lift pump,-08 fuel lines to filter/-06 filter to pump,separate return line, JRE 1/2" fuel pickup, DDIII's, Jardine 4" exhaust,ATS manifold, hot,hot Power Edge & coming soon:red L&L ladder bars, weber /-08 fuel line fittings--the above is a big fat lie I really own a totally stock RAM
chris sutton
