Blue box q's now transmission q's
First step
I finally have my blue box working good. Oo. Oo.
Now my transmission slips. :{ :{
I had bumped up my line pressure to 67-68 psi. I was told to not go above 70# by Bill K unless I change the acumilator spring. But I think at this time I need a temp fix. I cant aford a value body and converter right now. The parts and deposit would Just be to much right now. How high can I gowith my line pressure???? And at what point do I need a resitor to not set off codes?
I am only running the blue box only at 15 % also. Tomarrow I am taking off my ez and not use the blue box to reduce transmission stress untill I can get atleast a vb.
I will say even at 15%:--) The blue box it the bigest power increase so far
You could do that, but no thats not what I was refering to. I was talking bout a $75 to $100 Trans Go shift kit. As a Temp fix. And it might not be enough to handle the complete load depending how you drive your truck.
A valve body from Bill would be a better choice. Call him and talk to him.
On ICQ now.
As for how long your stock convertor will last? Thats the million dollar question. I ran a "Hot" PowerEdge with just a shift kit for over a year with no problems. It depends on how long you want it to last... ...
Its in how you drive it and treat it I suppose.
I've had just the VB in my truck for a year now. The TC held up to my BD 4 wire box, same as blue chip, fine. Now I added an EZ and it doesn't stand a chance. So with both of your chips "on", no, even with an upgraded VB it won't hold up long at all. If you only turn one on or the EZ and 15% or 30% of the Blue Chip, then you could drive it for a long time with just a VB. Like Kat said, it all depends on how you drive it.
Corey
VB only? until you have the full meal deal...
it's still only a "sack lunch" :(
Like they say <b>Pay me now or pay me later </b>
what are the conditions you are using the blue box for other than increasing fuel consumption and EGT ????
as far as increasing your line pressure , if bill suggested you don't go any higher without changing something else then its probably safe to say thats as high as you want to go .
there are other things that go along with a pressure increase that increase clutch holding line pressure as you increase speed . just turning up the pressure on a stock VB is a bandaid .
you ain't gonna like this but that money you spent on the blue box should have went into the trans . if i had to do it again , the trans is the FIRST upgrade ...
post electronics fueling is for playing ... you wanna play you gotta pay .
VB is minimun , whether its a kit you add or a bought and tested VB , your decision . but don't expect the stock TC to live a long and happy life , nor the trans as there are upgrades that need to be done for the power level you have the potential for .
I just orderd a vb from Bill K. And I plan on getting a converter and trans kit later. These trucks are expensive. You have the hop up expence and the payment. This month the payment is the small bill. :eek:
Clutch pac sh*t the bed for me, if your using the fueling box for sport, then your time is limited, with the fms and 275"s, I lasted 45 days, IT IS CHEAPER TO DO IT BEFORE YOU SMOKE IT
