I bought a (used) Blue Chip FMS recently. My boost went up from 16-17 stock to about 21-22 with the box fully on. I dialed it all the way up and will go to about 40% fueling with those boost numbers. (My truck is stock other than the box and BHAF and straight exhaust).
Since the fueling increases according to the MAP sensor reading of boost pressure, I believe my boost is being waste-gated at that 22 psi and therefore fueling will stop also. For those of you who do not know, the box will fuel up to 63% with enough boost, which I do not have.
Since it reads boost off the MAP sensor, can I put in a stand alone boost fooler to help keep the waste gate from opening so soon and dumping at 22 pounds?
I know most of you guys have boxes with a boost fooler or put one in with your injectors but I haven't and my box did not come with one nor did I expect it to. I mean, I am happy with the 5 or 6 psi increase but I know I can go more.
What should I do? Use a 22 shell, turnbuckle, who sells just the boost fooler?
Thanks a lot.
Thanks a lot.
