Engine/Transmission (1994 - 1998) Blue Smoke
Engine/Transmission (1998.5 - 2002) Hole in stock tank
Engine/Transmission (1994 - 1998) Water Injection Bad Oil?
possibly your valve stem seals are going bad, piston rings may be bad, but that is also normally associated with high blow by, possibly the seal in the turbo for the turbine side is bad, allowing oil into the exhaust. check your turbo. how many miles are on your truck?? how blue is the smoke? does the smoke smell like there is oil being burnt in the exhaust?? lots of things to consider.
wes
