Details here: TDR Privileges
Where'd you get the side view that you posted on the other thread? I'd love to be able to print that, and does the same site show other views as well? Thanks.
Sorry about that. It's a side view drawing of the CTD posted in your reply to "Angelbay" and his thread on "911" entitled "Fuel shut off won't activate... . ".
On the pasenger side of the engine, you have the exhaust manifold, turbo w/ wastegate, block heater, fuel injection lines/injectors, heat exchanger on the auto transmission trucks (and related plumbing), oil filter (w/the engine oil cooler behind that), plug to pull out for the barring tool, alternator, and the A/C compressor below that. Most of it is fairly easy to spot. There is a pass. side veiw in the Haynes manual, but it really doesn't show much of anything at all. The driver-side veiw is the same as what I posted above.
