Body Mounts
Body Mounts
Getrag Shifting Trouble
The welds on the passenger side of the rear cab mount has come loose (no rust) Has any one had this problem ,if so was it easy to get fixed or could this be a factory defect that the dealer should look at. The cab is 2"'s lower on the right rear.
1993 Power Ram 250 LE, 4x4
Welcome aboard '93 Dodge Man'. I think you will find a lot of useful information on this forum. I have not had any body mount problems as of yet. I do try to keep the underneath clean but it is hard during our winter months. Luckily I haven't notice any rust underneath the truck just yet. Not sure if a dealer would fix or not. You may want to check out Dave Fritz's web pages because he has a lot of info on the TSB's for our trucks. Keep rammin'.
Scott
92 Ram, Bright White, Club Cab, LE package, 4x4, 130K, 3. 54 gears, Auto, Extra transmission Cooler, 285x75x16 Cooper Discovery A/T, 16X10 American Racing rims, RS9000, Tekonsha, Running boards, Lund Sunvisor & bug shield, Marker lights, Tonneau cover, Full cap, DynoMax, 5" Chrome tip, 16 cm Turbo, Isspro Boost, 23 lbs Boost, Pump Adj, Sprayed in Bed-liner, Rubber mat
'SHAKES, RATTLES & GOES'
