I Know mine ROCK !!!!
Over head AVG miles keeps going up and up .....
3x3 is where Im running the comp ,,,the truck acts like its on 5x5 before the nossels but alot smoother ,,,seems to be better on thr tripple disk suncoast ...
Its suppose to be 75* tomarrow so the Bog down when placed in gear when under engine tempature will have to wait till it cools off ,,, Lowing the comp settings seem to lessen the drop in RPM but its not that cold out yet ... will see how they act at cooler tempatures.
Took a note on my way home from work
Cruise set @ 59 MPH
4 PSI Boost
20 PSI Fuel
600* Pyro
The cruise seems to be a little touchy compared to stock its not bad or anything just to be noted that when it calls for fuel it dont mess around anymore and it shoots the MPH neddle right up to where you want it ,,, then once in a while whips it back up to set speed ... . Not that bad really but not as smooth as with the stock injectors ... As Should be exspected .
Smoke isnt as much as once thought it was dark on my test drive and what seemed to be Coal Black smoke turns out to be a hase :< ... . LOL
But 5x5 WOT from a stop and it will lay a path till the Hx35 catches up .....
It dont smoke as much as the Catcher/ Hx35 21 Cm Ext housing Combo tho ... . LOL
Give me a few more days with some cooler weather and well see what there made of
thanks KERMA for the post... So these are called SPRINT 820 ???
DM
