Details here: TDR Privileges
I am replacing the clutch in my truck. if I remember right the torque specs for the flywheel bolts is 120 ft. #'s and the clutch cover is 26 ft #'s. Does this sound right? Thanks
My 99 manual shows: Flywheel, 101 ft. lbs. , pressure plate (clutch cover),5/16th bolts, 17 ft. lbs. , 3/8th bolts, 30 ft. lbs. Also have a Haynes manual, 94 thru 98 and it has the same specs. bg
