BOMB recipe
TPS installation...
ECM ?
So what kind of HP and torque numbers will I get if I treat a 96 215hp to the following 370 diamonds,HX40 16cm on an ATS manifold,#10 slide forward, governor spring kit,high flow delivery valves,timing at 16 degrees,4" exhaust,ported head. Did I miss anything?Would a 18. 5cm on the HX40 be better?
88 GMC CREW CAB 4X4 89 6BT,NO INTERCOOLER YET,AUTO METER LIQUID FILLED GAUGES,NV4500,NP205,4. 10's,35 BFGA/TKO,6" LIFT,DETROIT LOCKER,16CM,K&N,3. 5 EXHAUST,BD "PRINCE OF DARKNESS"INJECTORS 96 215 hp on the way. J. Mason
These guys have almost the same setup as youre talking about. Guestimate about 400 HP. https://www.turbodieselregister.com/ubb//Forum1/HTML/002649.html
I'm still trying to gather enough $$$ to do this. (this isnt my only expensive hobby #ad
Eric
98 Quad cab 4X4 2500 12 valve,5 speed,3. 54 rears, 8' bed. Michelin 275 75 16 lr-E. Boost and egt gauges but basicly stock except for a "properly adjusted" AFC. Cat in the garage. Uniden HR 2510, Texas Star 1200 amp. 63,000 Mi as of 1/27/01.
NRA life member. High power/IDPA.
A cheaper solution to 400hp would be the 16cm housing, for lower EGT & the #5 plate. It's about 380 centered. The chart tells it all. #ad
http://www.dieselpage.com/tstpk.htm
Jim Leonard has the #5 all the way forward in a 215 pump & the stock turbo. He's drawing cool air from the hood scoop to keep EGT down. #ad
Money Sink - 96, 5 speed, TST 380, HX40-16, 300 HP Injectors, Scourge BD 4200rpm Governor kit, McLeod, 4", CATless, straight out back, chrome turn down, ISSPRO Pillar, Delvac 1 & Amsiol, K&N, Mag-Hytec, 3:54, Michelin 235s on Alcoas, Rancho 9000's, Valentine One.
Dutchmen 27' 5th Wheel.
GoldWing.
I feel the 10 is much better than the 5 in a 215. The combination asked about should give around 450 hp (with the correct injectors).
What are the correct injectors,and are there any better,Better atomization. With the same or better performance. DD's?
you could expect 400 hp from that combo for sure. I had both turbo housings and the 18. 5 had to much lag for me but the 16 is just right, you may give up a couple of hp but worth gaining the drivability.
