Vaughn MacKenzie
I just installed 1/2" plumbing from inside the tank pickup to the filter canister. I put a Carter HP 100gph pump in front of the tank and don't have the stock pump. I added a 1/2" tube inside the pickup assembly because the stock one looks so restrictive, barely a quarter of an inch.
I got it all together tonight and it started easily enough after running a couple key cycles and priming it. I let it idle a couple minutes and had great fuel pressure, right at 15psi. Took off for a test drive and strangely the pressure began to drop immediately and continued downard to about 4psi. I stopped and sat there letting it idle and it gradullay worked its way back to about 12. But the moment I started driving it nosedived again. I headed back to the house and then it continued downward to 0, then it began to sputter and miss, and then it conked out.
I cycled the key and the pressure came back up to 15psi. I cycled the key repeatedly but after trying for half an hour it refused to start. My neighbor came along and towed me home with is Ford Escort :{ :{ :{
I have about 1/8 tank of fuel in the tank. It seems the pickup is getting a lot of air. It is about 1/3" off the bottom of the tank. The problem I fear is, the tank pickup is a complicated contraption designed to hold fuel and keep the pickup in constant prime when the tank is low to prevent air from being drawn up. Unfortunately I couldn't install the larger tube without defeating this. My fear is I am now screwed and will have to buy another pickup assembly for big $$$ and my whole project that I've been busting my butt on for the last 3 nights is all for naught
I'm wondering if anyone has any ideas. Tomorrow I will fill the tank at least half way and see if the problem subsides. If it does I know it's a pickup problem. If not, then the next thought is the new pump is defective.
Thanks,
Vaughn
Thanks,
Vaughn
