Bombers to 4000 rpm, any cam failures?
Tool Box for short bed
Lubing calipers
Just curious, anyone split the nose of the cam shaft and loose the gear?
1997 Cummins Dodge 4x4 Bombed & Amsoiled
Member of TDR,LIC-ROC,GLTDR,NRA
[This message has been edited by MGM (edited 08-22-2000). ]
Sounds like a paranoid rant to me #ad
: The 12 valve engines have a harmonic problem about 4100, if you can get thru that 4100rpm range quick enough the bottem end doesn't come apart until about 5400rpm's. But the engine doesn't make good useable hp over 3600 anyway so there's not point in going to 4000, unless you're just testing things to see when "****" happens #ad
Piers
Piers,
Is that the voice of experience? #ad
Joe George
Eureka, CA
'95 2500 CC auto 4X4,Combo EGT/boost guage,custom switch panel,PacBrake,TST #5,BD valve body,Automatic motorhome steps on both sides,Foldacover hard bed cover,Cummins chrome kit,Black steel grill guard,Front hitch receiver
No problems with the cam yet at 4200. I need to go to the heavy valve springs this winter.
Smoker
96 2500 4x4 nv4500 3:54 slt 3"body lift 2. 5" suspension by skyjacker 267/75/16 street tires 36/12. 5/16 swampers for mud silencer ring lost 5" pipe borla KN round style filter JRE stage 4 400hp JRE afc spring kit boost and pyro gauges 16 housing pump timed and 3000rpm limit now 4200
