I've got an 81 Isuzu pup with a n/a 2. 2 diesel and am in the process of rebuilding it and adding a turbo that came off a benz. My turbo guy says that this turbo is capable of producing at least 30 lbs. and it has an adjustable waste gate. I'm wondering if any of the diesel gurus here have any advice. Questions i have are how much boost can i safely run, will changing the cam duration be better, how about bigger injectors, should i do any pump mods, and will this poor little four cylinder hold up to this added power. Anything will be an improvement because my 02 KW loaded at 105,500 lbs. will blow the doors off this 326,000 mile wonder, and God forbid there be the slightest hill ahead of you, but it still gets 40-50 mpg. This truck i going to be mostly an off road toy, but I want it to be reliable enough to be an everyday driver if need be. Also being done right now is adding power steering out of a Trooper, an independent rear suspension out of an RX7 four linked, modified IFS, 3" body lift, 35" BFG muds, all of this custom fabbed by me and my buddy in his shop. Any help would be greatly appreciated because all I've ever bombed before is V8 gassers, and all my knowledge about diesels is what I've learned from this awesome site. Thanks in advance.
