Vaughn MacKenzie
My buddy recently got a '82 Blazer with the 6. 2 and I am in the process of also buying a beater '82 Blazer with the same engine.
My buddy's rig runs pretty good, it accelerates as good as you'd expect a 6. 2 to run, but even at full throttle it doesn't make one bit of smoke. Once it made a miniscule puff when I was behind him and he hammered it to pass someone.
Can you turn up the pumps on these? Certainly you can add more fuel and actually make it smoke a little! The exhaust is pitiful, all the way from the super restrictive manifolds to the wussy 1. 75" plumbing for each bank. The clearance between the frame is so tight headers look to be out of the question, but has anyone heard of headers for these??
The general plans for BOMBing that I have for my rig is a mains girdle, turn up the fuel and upgrade the exhaust. For 160K miles and sitting 8 years it runs pretty good. The motor sounds tight and smooth, very little blowby. The owner retorqued the head bolts at 100,000 miles and hasn't had a lick of trouble with the engine since new, other than being hard to start after sitting awhile. He also defeated the EGR since it was almost new so that probably helped a lot.
Vaughn
Vaughn
