I am looking for opinions on replacement batteries for my 98. 5 Diesel. I have done some research and read all the posts about the Optima batteries but have some concerns. The list below is a comparison of Cold Cranking Amps, Reserve Capacity, and physical size of batteries. The Cold cranking amps is a measurement of how much current can be sucked out of a fully charged battery at 0 degrees F with the voltage not falling below 7. 2 volts. This is important for cold weather starting or when operating a winch. The reserve capacity is the time it takes, in minutes, for the battery voltage to fall below 10. 5 volts while supplying 25 amps. It is measured when the temperature is 80 degrees F. This is important if you are far from home and your alternator fails or your headlights are left on with the engine off.
Stock Dodge Battery:
BCI group 27, 12 1/16 x 6 13/16 x 8 7/8
CCA 750
Reserve Capacity 150 minutes
Optima Red top:
BCI group 34, 10 x 6. 8 x 7. 8
CCA 750
Reserve Capacity 104 minutes
Optima Yellow top:
CCA 550
Reserve Capacity 120 minutes
Interstate 31P-MHD:
BCI group 31, 13 x 6. 75 x 9. 375
CCA 950
Reserve Capacity 195 minutes
Both of the Optima batteries are slightly underrated when compared to the Dodge battery. The Interstate 31P-MHD is about 1" too long to fit in the battery tray but by cutting the front lip off the tray it will fit in the space allowed for the batteries. Unlike other group 31 batteries, this one has the standard automotive style terminals and should not require any fancy adaptors to make the connections. I am sure it weighs more than the Dodge battery and a lot more than the Optimas.
Has anybody tried one of these commercial batteries in their truck? Is there a reason this won't work, before is spend the dough?
edit:
I was all set to buy the Optima batteries, but their lower ratings bothered me. It seems that if Dodge could get away with a smaller battery they would have done that (and saved a few bucks). I have read that there are a lot of people running the red and yellow top batteries but how long do they last.
CCA 750
Optima Red top:
CCA 750
Optima Yellow top:
CCA 550
Interstate 31P-MHD:
CCA 950
edit:
