RT66DOC said:What happens if the stock turbo is used with these mods?
Starting with a '96 5spd 215 pump truck, consider the following power enhancements: #10 plate, 370 injectors, 3K GSK, timing 15. 5, Scotty Air, 4" turbo back exhaust. What happens if the stock turbo is used with these mods?
Forrest said:Nuclear hot EGT. With the same truck/starting point as you, I ran a #11 plate with 300 injectors & was @ 1500 degrees.
NWitmer said:I have a 1994 160 pump converted to 5 speed
with 370 injectors 191 dv custom plate simaler to the 10 plate
37# boost stock turbo max egt 1375 WOT
pwerwagn said:A mod'd HX40 might suffice (something like the DD jammer) also.
mjs said:. Smashing and bending the return line was a major cock . I would highly suggest a bolt on should be marketed
RT66DOC said:Starting with a '96 5spd 215 pump truck, consider the following power enhancements: #10 plate, 370 injectors, 3K GSK, timing 15. 5, Scotty Air, 4" turbo back exhaust. What happens if the stock turbo is used with these mods?
