Matt42
Over the weekend, I changed out my heater core that had a pinhole leak. It was a MESS, closely resembling oxide copper ore from the Globe district. The job wasn't all that bad, but a 30 inch broom handle was essential.
While I had the HVAC box out, I also replaced the air conditioner evaporator and the accumulator. The evaporator had the beginnings of corrosion on the base.
When I put it all back together, I followed the advice of the Dodge 1996 TSM and added 6 ounces of PAG oil to the system. I poured it into the accumulator. Then I reconnected everything with new O-rings and garter springs. I vacuumed out the system for about an hour, and managed to pull 28 inches of vacuum. Then I recharged with about 32 ounces of R-134.
Inlet and outlet pressures are OK, but the air temperature at the center vent will not get below 55F when it is 90F outside.
What did I do wrong? Did I use too much oil? Did I put it in the wrong place? Is my karma going away? The mixing door and cable work fine. I've done work on R-12 units, but this is my first foray into R-134.
Any advice will be appreciated!
