No, I'd never make it as a mechanic! Today, I changed the oil, air & fuel filters. Not noticing which way the old air filter came out, I studied the new one as to which way must be correct (even had a 50-50 chance. ) After putting everything back together, and priming the fuel system, I cranked it and it fired for a split second, but died. Did that twice. Cranked a little longer the third time "to get more fuel in there". When it failed to even try to start, I checked under the hood to see the air ducting sucked in on itself, and slowly releasing back out.
Lesson: The '93's won't start/run with the air filter in backwards.
Cheers!
Scott
Cheers!
Scott
