Our 98. 5 24v has been running bad when cold no power then it will just pick up and run fine been doing it for about a years. I came home for Thanksgiving so I thought I would try and read some codes with the smarty……P0216 :{ not the number I wanted to see so the vp44 is probably the problem any thing I should check before I get a new injector pump? LP is good seeing about 7 psi @ WOT 12psi @ idle the truck is stock except for the Rv275 injectors VP44 was new 60k ago and always keep a watch on the fuel pressure.
