Are you stock? Normal stock boost with the 12 valve 180HP auto is about 18-19, I'm not sure with the 5 speed but I believe it's around 21-23 with the 215HP engine. Boost is not adjustable unless you add something like a TST kit with an adjustable elbow that changes the pressure signal that goes to the wastegate. If you are stock, there is nothing to be gained by increasing boost. More air without more fuel actually can reduce power. Read the excellent posts on "Wastegates" that are very recent threads. You will learn a lot. I actually reduced my WOT boost by 4 pounds after reading the posts and my egt's are reduced without adding smoke and the engine should now be more efficient.
