I am wondering how much boost you guys are seeing from these engines in stock form. This would be a 93, I can't hardly get it up to 15 PSI, and I have never seen the pyro over 1050 pre-turbo. Doing some research it looks like I can turn the starwheel counter clockwise to get more low end power, but how much should a guy turn it. This engine isn't in a pickup any more it is in a service truck that I built this winter. It's weight is about 14,000 lbs the wai it sits in the picture, so it puts a fair load on the engine. It is also geared pretty low, in the range of 55 MPH at around 2000 RPM. Would it be ok to turn the star wheel a little bit, or should I look for a different exhaust housing for the turbo first? I thought maybe the pump had been tweeked, but if it is it isn't much. By the markes used to line up the injection pump it has been advanced about an 1/8 inch or a hair more. Thanks in advanced
