Details here: TDR Privileges
If you are drilling & tapping for the pyro in the exhaust manifold (preturbo) watch out for the middle vertical casting web. Stay 5/8" to left of center if you want to avoid it.
I drilled in the center and hit the web. Had some difficulty but got lucky and it worked out. I Strongly recommend you remove the turbo to do this.
I drilled it with the turbo off but when you drill it in the end of the exhaust manifold like I did then it only reads the front or rear three cylinders(whichever side of the web you got on). :--)
