boost and temp gauges
Lock-up Question
Front Wheel Spacers
Still new at this so bear with me. I will be getting gauges from Santa Claus this year and I am wonder were the best place to install the probes for boost and exhaust would be. Also getting the pillor mount too. If possible could someone help me out with a picture or two showing where to install probes thanks.
There are several places that you can install those probes. For the EGT you can drill and tap the exhaust manifold for preturbo temps or the elbow out the back of the turbo for post turbo temps. Wont get into the pre/post debate. Drilling and tapping sounds scary but it really is easy to do just take your time. Do a search and you should be able to find detailed instructions for it. As for the boost gauge you can also do one of several choices. One is drill and tap the intake horn, second you can use the port on the head back by the fuel filter housing. Just unscrew it screw in a bushing adapter of the right size or I beileve that Piers has a bolt tapped that just replaces one of the intake horn bolts. Hope this helps some.
