Boost Bolt
Help for a neophyte with a Jacobs EB on a new 600
bypass oil filter
I got a boost bolt with no instructions on what bolt to replace on a 03. The picture shown was for the older 24v.
Is there a specific bolt I am supposed to replace. I installed at the bolt hole that is the front most and closest to the head. I am getting about 22lbs of boost here. Sound right?
Where can I get a "boost bolt".
Never heard of these. Look like a better
option than drilling the intake horn.
Thanks,
Carl
amsoilman; how did you get the bolt in there? I had to put mine back a cylinder and even then it very slightly touches the injector fuel inlet bolt. At the location you've shown the fuel lines are nearly directly over the intake bolt on my truck. No room at all to put in the boost bolt. Just curious how others have been able to get this extra space since as mine is now I'd have to take the boost bolt out to retorque the fuel inlets.
Big MAK
I don't know where you got your bolt, but mine just went right in, as you can see. Nothing around it to interfere with it.
Wayne
amsoilman
Sounds like my bolt it just too big. It came with the kit from Geno's. Although I have one from Pier's that's the same size. The one you have in your pic is definitely smaller. Where'd you get that from?
