I just helped a friend disable his wastegate with a J-hook. His truck is stock other than a 4" exhaust and K&N air filter. After the work was done he took if for a spin and only hit 23 lbs of boost. I was a bit puzzled as I expected to see him get to at least 30 lbs.
I can hit 34 lbs on my truck easily but then again I have a catcher ECM. Does he need a fueling box or did I not tighten the J-hook enough?
Thanks
Phil
Thanks
Phil
