I am very impressed with the eBay boost controller from Lower Shores Performance I just installed. I used shop air regulated to 35psi and connected it to the boost controller inlet. I then adjusted the controller, It works best on my Cummins with the bleed off or fine adjustment barely cracked open about 1/8 turn, the waste gate still closes fast. I then adjusted the coarse knob until the waste gate just started to open. I then connected the inlet hose back to the AFC fitting and road tested the truck to fine tune it using the coarse knob. Now the boost will spike to 36psi and then settle at 35psi every time. I could not get steady readings with a boost elbow.
