I seem to be loosing boost - not a lot, and I'm not sure why, or if it's even a problem.
When I bought this truck 2 years ago with 144k on it I'd get 11-12 max boost, and It would run 4-5 at 65-70 on the highway. I added a BHAF and Powerwagon injectors last summer, and in addition to a NOTICABLE performance increase, my boost would max out at about 15, occaisionaly 16, and run at around 6 at 70 MPH.
We recently had a real bad cold spell, and a short time after that I noted the boost numbers had fallen off. I did some surfing with the search feature but was having a hard time getting a reading on what my problem may be. My tire pressure is the same, EGTs are running about the same, and performance doesn't really seem to have fallen off. If anything, fuel mileage has slipped a little. Boost max's out at about 11 or 12 now, and I run at aobut 2 or 3 at 70 mph now.
I looked under the hood and can't see anything obvious in the turbo intercooler plumbing. I squeezed and felt all the connections while it was running but as I said, nothing that I could see.
I also checked the boost gauge plumbing, but again, nothing obvious.
I don't know if the cold caused something, or was purely coincidental.
The only engine mods are the ones noted, i. e. , I haven't tweaked the pump at all. Recent maintenance includes an oil change 1k back and a fuel filter change 4k back.
Like I said, it seems to be running just fine, but I'm baffled at the boost drop. Thanks in advance for any input!
