Boost?EGT Gauge Wiring
BD PressureLoc
Nevada Pinstripes
Just received my gauges in the mail... understand most everything but how to wire the lights... . I believe than Evan mentioned in an earlier post that you can tie in to an orange wire under the dash... where is the best place and can I attach both gauges wire to the same one or to each other... also where is a good source for a ground ?
2000 2500HD QUADCAB CUMMINS, AUTO WITH 3. 54'S,LB,4x4,ALL OPTIONS MINUS LEATHER,UWS DP TOOL BOX,SPORTMASTER CUSTOM MADE SOFT TONNEAU,CARR STEP, VENTVISOR, PATRIOT BLUE/DRIFTWOOD
Jeff,
The orange wire is the one you want to tie into if you want to dim the lights and not use the fuse tap method. It is located under the dash in various places. Various places you say? Well, I have done 4 different trucks, and the wire is in a different place on each one! Go figure... If you don't want to dim the gauges, just tie into the parking light wire, which is BLACK with a YELLOW tracer. Again, this one is under the dash. #ad
As for a ground, just pick a place where other ground wires are connected. #ad
BOMB ON
Evan A. Beck
Prez, NW BOMBers
98. 5 2500, 4x2, RC, ISB, A/T, SLT, 3. 54 LSD, Trailer tow, Aux. suspension, Forest Green/Driftwood, 54,625 miles, 02/08/00
4" "PIPE BOMB"--straight piped exhaust split into duals, with 4" x 20" chrome tips one on each side after the wheels, Jacobs E-Brake, K&N Filter (Scotty style), Auto-Meter Ultra Lite boost & pyro, turbo silencer ring removed, OEM foglamps, OEM roof marker lights, OEM 1-ton tailgate marker lamps, 6-way amber turn signal conversion, Sylvania Cool Blue® 9004 headlamp bulbs, Husky diamond plate toolbox, Line-X spray-in bedliner, Mag-Hytec rear end cover, painted exhaust manifold and turbine housing, and E-Brake elbow, plus other cosmetic modifications
2001 ETH DEE 2500 4x2 QC SB ordered 02/13/00
"I'd Rather be RAMMIN' than STROKIN'"
"Journeyman B. O. M. B. Member"
Ground Zero--BOMB Page
Jeff:
Like Evan say's use the orange wire (small #22 awg). The easiest place to get it is to remove the ashtray light (unplug it from it's wiring harness), splice your two wires from your gauge lights one to the orange and one to the orange/blk wire and yes you can parallel the gauge lights together, then replace the ashtray light and plug back into the harness.
Ron.
'00,2500,4x4,QC,LB,6spd,3. 54,4wABS,Camper-Trailer packs,BD Brake,Pullrite 20. 5K 5hitch,Tekonsha EnvoySV,CobraCB,Flame Red/Silver.
