Hey Group,
Recently read on the forum here where a little more boost might bring the EGT’s down. I’m thinking that sounds great! I’ve got an 01 ½ - 2500 with an auto, and (Dare I mention it?) Banks Big Hoss! <GASP!!> (s’ok, I’m pleased with it). Oh yes, and the 4” AFE exhaust throughout.
The Banks isn’t messing with boost as far as I can tell cuz I’m still showing 20-21 psi, which I understand is normal. Generally I don’t have too much problem with my 9k trailer pulling Colorado passes but the EGT’s get up there, and I do back it off when I see 1250 or 1300 degrees Pre-turbo.
What I think I’d like to do is get the ADD(boost fooler) from Haisley and a J hook, and bring the boost up to about 25 psi and hopefully bring EGT down. Is the J hook adjustable to dial in the desired boost rate or does it just boost to 30+? Oh, I did read also that the 01’s have an adjustment screw for the wastegate, maybe all I need to do is tweak that once the ADD is in place. Any thoughts and/or consequences with this setup?
Thanks in Advance for your inputs.
