Boost-EGT's Hi Fellas, A few questions for you... . First off, my truck is stock except for the K-N. It has the 21cm housing. Now have guages (thanks Pastor Bob and 24 Valve Chevy). The highest boost reading is 12lbs on a long hill, running empty, and at sea level, with it pegged to the floor. 1) What is normal boost for a stocker? 2) Is boost influenced by elevation, atmospheric air pressure, and ambiant air temprature? Also, I've been unable to get the pyro into the yellow (1050 degree) during that long uphill pull. 3) Does the pyro temp. seem normal? 4) Could it be effected by winter-diesel fuel or fuel additives? 5) Muffler? Any thoughts on these questions... ... ? Thanks... .
