Boost elbo ??????
stumble on startup
truck is a slug...suprising dyno results!
A boost elbow blocks part of the boost signal going to the wastgate actuator. It allows the turbo to build more boost before the wastegate opens. You need to run a boost fooler with it to take advantage of it. Otherwise the ECM will see the over boost and defuel. Most power adders have boost foolers built in
wtfd6 said:
hey dm, if cryotek doesnt want it i could use it. my rv275's are on the way. i know i will need a boost fooler also. that is next on the list.
mark
You need more that just the elbow BD-power sells a boost fooler wiring harness you will need. The elbow provides the boost you still need something to trick computer
