Boost fitting and transmission temp sender
First Post
Ticking and #5 injector line
Two questions:
•Where is the bolt that you take out to install a boost gauge on an 05?
•Where has everyone been installing electronic trans temp probes? Can a "T" be put into the outlet to the cooler? Again, this is for an 05.
Transmission temp sender location
None of the pressure port plugs have fluid flow in all gears on the transmission. That is why Mass Diesel has made their modified cooler line. There is flow through the cooler in all gears of the transmission. IMHO this is the only aceptable place for the sender for transmission temperature. Do a search and you will find a rather long post describing which ports have fluid flow in the various gear selections. Ken Irwin
